Flywheel Removal? How To.
Posted 31 March 2011 - 06:34 AM
I've purchased a 1300 SPi engine and I'm in the process of stripping down for a refurb/rebuild. The usual expected spec. Lightweight flywheel, larger valves opened ports and skim. New cam, rockers etc. stage one and hif44 carb. Hoping to produce something nice.
Sadly though I have got to a place where I am now stumped by removing the flywheel.
The Haynes joke book (a hallowed tome) says to pull it off with Rover Tool ??????? or a similar puller. Well I am on a similar puller and I thought I would check before ripping the clutch plates and housing off the face of the flywheel.
Can I pull against the clutch mounting ring? (I mean the ring around the clutch plate which is bolted in 6 places to the flywheel) as I cannot see where else to attach the puller. There are no tapped holes and the cowling/casting is very close to the ring gear so I cannot get down the sides. (can I remove the cowling/casting?)
Comments would be appreciated (keep it clean) as they always are.
I know it will be tight, it's a verto clutch and it's taper mounted.
Thanks in advance
Posted 31 March 2011 - 06:49 AM
You NEED a flywheel puller...
http://www.guess-wor...play.htm?id=501
Edited by Guess-Works.com, 18 August 2016 - 09:50 AM.
Posted 31 March 2011 - 08:01 AM
Posted 31 March 2011 - 07:25 PM
Posted 31 March 2011 - 08:31 PM
did mine with a halfords one, worked fine.
ruler is so the legs going into your flywheel are all the same length so it comes off level. Tap whe you wind on the black nut and should pop off if you are lucky, but they can be an arse to get to pop !!!
Graham
ps 998 mine not an spi so may be different but can't see why !
Posted 31 March 2011 - 08:45 PM
Cause i dident and could i get the thing off noooooooooooooooooooooooo lol.
spi clutch is different than a normal verto clutch as it has sensor pickup plates on it.
Edit - Spelling
Edited by ukcooper, 01 April 2011 - 10:01 AM.
Posted 31 March 2011 - 10:22 PM
As always all information is greatly recieved and I have purchased the Halfrauds puller but I haven;t yet tried it out due to being held up at work etc.
I will repost with news. If you don't hear the bang when it comes off.
stay tuned
Minitman
Posted 31 March 2011 - 11:14 PM
Off topic bit
Oh and for reference the automatic convertor has 6 bolts but you must never ever remove all 6, only remove 3 for the purposes of removing the convertor.
Edited by mra-minis.co.uk, 31 March 2011 - 11:15 PM.
Posted 31 March 2011 - 11:48 PM
Posted 31 March 2011 - 11:51 PM
Posted 31 March 2011 - 11:53 PM
Posted 01 April 2011 - 02:12 AM
Posted 01 April 2011 - 11:13 AM
Posted 01 April 2011 - 11:32 AM
How did that get through the swear filter???t**ting it with a big club hammer, lol!
Family forum remember...
Edited by L400RAS, 01 April 2011 - 11:45 AM.
Posted 01 April 2011 - 02:07 PM
