Brake Master Cylinder Options
Posted 28 January 2011 - 03:37 PM
I'm running 4 pot alloy calipers up front and drums on rear by the way.
Thanks,
TC
Posted 28 January 2011 - 05:12 PM
Posted 28 January 2011 - 05:31 PM
Posted 28 January 2011 - 05:34 PM
The main reason for the larger 'S' cylinder is the capacity, 4 pots displace more fluid. So as your pads wear you need all the capacity you can get.
Quite true, but your brake fluid level should be checked regularly anyway..... of course, we all do this weekly as the handbooks tell us...... don't we???
Strictly speaking, you can't use an adjustable valve inside a road car and it should have dual circuit brakes if it's post 1976.
Is this a Construction & Use Act requirement?
Of course, not a problem if it isn't a road car.
Edited by ado15, 28 January 2011 - 05:36 PM.
Posted 28 January 2011 - 10:19 PM
Posted 28 January 2011 - 10:23 PM
Really? Every car I have has one (apart from my daily company thing). I presume most MOT testers are unaware of this rule... thank deity of you choice.
Posted 28 January 2011 - 10:27 PM
I have a yellow tag MC with the pressure limiter on the X-member removed and adjustable bias valve plumbed into the rear..
Don't know how well it will work yet though! still not got my engine back in.
Posted 28 January 2011 - 10:51 PM
No, it's just nothing to do with the MOT is all. It's still illegal. To get a bias pedal box through the IVA for example the adjustment has to be welded up, and not just a little spot of weld that you could chip off but complete seam welding of the nuts to the thread and the unused thread destroyed. It's considered acceptable to have an adjustable bias in a car that hasn't been IVA tested but just modified if the adjustment cannot be reached from the driver's seat, but I don't know if that's actually legal or if it's been tested in court.
Posted 28 January 2011 - 10:56 PM
That fine then.
"IVA's are make believe, like elves, gremlins and eskimos" Homer J Simpson.
Posted 29 January 2011 - 08:26 AM
I have just been playing brakes on mine this winter..
So a twin outlet one will work fine with an adjustable rear line? If so is the MC you are using a standard mini one or are there still differences- and can I assume it will be cheaper than the big reservior cooper s type ones I seem to remember as being rather expensive?
Posted 29 January 2011 - 06:03 PM
yes it's just a standard mini mini yellow tag MC usually on ebay for about a fiver
it can be expensive though as the regulator costs a bit...
Posted 29 January 2011 - 08:40 PM
Posted 29 January 2011 - 08:45 PM
http://cgi.ebay.co.u...a4#ht_502wt_905
Posted 29 January 2011 - 08:57 PM
Posted 31 January 2011 - 04:34 PM
I am reading this topic with interest because i plan to do the same modifications.
But is it not suppose to be the top hole of the master cylinder linked to the rear brakes?
