Rev Counter ?
Posted 06 January 2011 - 03:20 PM
Posted 06 January 2011 - 03:45 PM
Posted 06 January 2011 - 03:54 PM
Posted 06 January 2011 - 05:16 PM
Yes, an easy jobyes you have to wire it on the coil.
Put mine in a pod and mounted it behind the steering wheel. Have you got a central speedo or a twin behind the wheel type?
Posted 06 January 2011 - 05:36 PM
Bit of a hijack here but can you fit any after market rev counters to these connectors or does it have to be the standard one from the 3 clock setup?Dependant upon the age of the car, the wiring may already be there in the existing loom & just needs connecting to the new rev counter. Later two clock instrument dashes had the rev counter wiring in the loom as standard. <you>See This Thread - Click Here</you>
Posted 06 January 2011 - 06:19 PM
Posted 06 January 2011 - 06:51 PM
Diagram is for a TIM 52mm rev counter fitted to my VW van, not the old Smiths one in the picture I posted. Most modern rev counters will be wired in a similar way to the diagram.
