Electronic Ignition Wiring
5 replies to this topic
#1 AndrewUK1990
AndrewUK1990
  • 33 posts
Posted 30 October 2010 - 07:51 PM
Hi, i have a mini with a recently fitted MG Metro 1989 unleaded engine fitted. It has an electronic dizzy but i dont have the original wiring for it. My mini has an 89 wiring loom and i was wondering what colour wires come out of each pin on the three pin connector on the mg metro dizzy. I know that i only need to use 2 pins, and take a 12V+ and 12V- on each side of the coil but because i dont know which colour wire goes where on the dizzy socket i cant wire it up.
I could try wiring it up testing each pin to find the right way that works but i dont want to damage the dizzy so im not doing that. Can anyone provide me with a picture to show which colour wires plug into the socket on the mg metro dizzy. This would be greatly appreciated because i cant find anything to show me on the intyweb :thumbsup:
Picture of the 3 pin module which is attached to the side of the dizzy looks like this: http://www.lrseries....ODULE-3-PIN.jpg
Thanks in advance!
Andrew.
#2 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 30 October 2010 - 08:23 PM
Have you got the plug connector that goes onto the module. I thought it only had two wires red and black. The red needs a permanent 12volts from the fuse box and the black goes to the coil. Im pretty sure this is how ive connected mine up!!!
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 31 October 2010 - 09:37 AM
Any help to you?
#4 mars red mike
mars red mike
  • 1,500 posts
Posted 31 October 2010 - 10:07 AM
Any help to you?
Thats a useful little picture that is. Ill keep that one. Ta mate.
#5 I-B-Quick
I-B-Quick
  • 82 posts
  • Local Club: n/a
Posted 31 October 2010 - 04:54 PM
I have the same setup -
this may also help you...
http://www.theminifo...tronic igintion
#6 AndrewUK1990
AndrewUK1990
  • 33 posts
Posted 14 January 2011 - 12:45 AM
Thankyou very much to all of you, this has helped me figure it all out. Sorry for the late reply.. bt better late than never! Thanks again, problems solved!
