Zcars's Chassis Kit
Posted 15 June 2010 - 01:06 PM
I am new in this Mini World thanks to Zcars's ultimate space frame chassis. looking forward get one soon. before that I would like to clear some of my doubts regarding the mini conversion.
from what I observed, the kit requires to cut a "certain" amount of floorpan for the engine to be fitted to MR. But if you refer to the photo below:
the area where the chassis kit will be mounted is just a very thin guage metal sheet, won't it just shear off once the engine torque or the weight of the mini sit on top of the chassis? as shown below:
it looks likes the whole rear chassis is hold by the few tiny little bolts and nuts to the space frame, is that right?
Posted 15 June 2010 - 02:50 PM
Edited by Timify, 15 June 2010 - 02:50 PM.
Posted 15 June 2010 - 03:42 PM
Posted 15 June 2010 - 11:33 PM
let say an X door bar and roof bar, that is 12 points of mounting to secure the front and rear together. am I get it right?
Posted 16 June 2010 - 08:56 AM
The way the clamps are made, they are welded to alternate side of the tubing. The tube sits completely within the clamps. The force will go through the tubing, more so than the bolts. While they are expected to provide some protection. The main force from an impact will be taken with the tubing or the welded bracket section (or clamp).
Each side of the clamp is welded onto the alternate tube. the force will more so, go through this and the opposing tubes/clamp, put in place to cope with the impact. Not the bolts.
A lot of design work is put into a roll cage, each tube and mounting point is designed to protect from impact in a certain direction, with others in place to strengthen its weakness as best they can. If forces where expected to go through the actual way its held together, we'd be using bolts a lot bigger.
If you are still unsure of the safety there is a video somewhere of Chris in a 90mph+ shunt on track. I'm sure there have been many more too. My point being, these things are tried and tested, raced, dragged, driven and even crashed. They are an out and out pedigree, and Chris is very good at what he does. If you are still unsure, perhaps Chris will be able to explain further and better than I am able to.
Posted 16 June 2010 - 09:24 AM
Posted 16 June 2010 - 10:11 AM
Z Cars do, do a weld in frame for race... Well technically they can make what you like if you ask.
Posted 16 June 2010 - 01:12 PM
Posted 16 June 2010 - 10:37 PM
erm... any one has Chris's email or is he on the board? )
Posted 17 June 2010 - 08:10 AM
Hi,cheers guys....
Just read your post and understand your concerns. I bought my (bolt in) kit back in 2006, so one of the early kits, and even back than the product had been developed for years. It has been crashed many times with very positive results in terms of safety. He even mentioned a client of his drove his Zcars mini into a bunch of trees at 60 mp/h and escaped unhurt.
But I agree, just call Chris and talk to him and go for a spin in one of these monsters. You'll be amazed by the stability and stiffness of the whole package. And if you're still not convinced about the strength of the bolt-in frame (which I doubt), just go for the race spec conversion, which is fully welded from back to front, which is the frame that CPTKIRK shows in his pictures.
Just mail Chris at: [email protected]
Wish you a lot of good luck and good fun!
Nick
Posted 18 June 2010 - 10:30 PM
Dont worry about any structural damage. These kits are rock solid. All the forces from the engine & suspension are taken by the rollcage/subframe. The bodyshell is there to keep you dry & wind off your hair. My car is a Vtec been done for 3 years & not a single problem.
Ben
Posted 19 June 2010 - 10:32 AM
cheers
