Interior Without The Two Rails/dash/facias
40 replies to this topic
#31 minivtec1.6
minivtec1.6
    Just On Tickover
  • 7 posts
Posted 27 September 2011 - 06:05 PM
I took mine off but the switches stick out, what has everyone done about that?
#32 analogue_radio
analogue_radio
  • 4,897 posts
Posted 27 September 2011 - 06:38 PM
I bought an earlier switch panel and welded in patches to make the gap smaller.
(Needs fillering)
Edited by analogue_radio, 27 September 2011 - 06:39 PM.
#33 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 27 September 2011 - 09:25 PM
I forgot I had already posted in this thread it had been so long ago, I almost posted pictures of Sonic again!
#34 Zulu162
Zulu162
  • 95 posts
Posted 02 October 2011 - 10:09 PM
I cant seem to remove the top part, I cant get to the centre nut atall, I was told that i need to remove the windscreen to take it completely out? True?
Regards, Duncan
#35 retroracer1275
retroracer1275
  • 543 posts
Posted 02 October 2011 - 10:25 PM
i havnt got them :P
#36 Zulu162
Zulu162
  • 95 posts
Posted 03 October 2011 - 10:18 AM
i havnt got them :P
Cheat-much :D
#37 Hegnirst
Hegnirst
  • 3,496 posts
  • Local Club: Hilltop Minis
Posted 05 October 2011 - 03:39 AM
what i did about them sticking out is, i un-scewed the bolts from the back, took out the bracket that fits between the switch panel and the body work and bolted it in place through the holes already provided with some nice rounded bolts.
this was in my last mini -
the first picture is how i bought it, the second picture is after getting my hands on it... :P
Edited by Hegnirst, 05 October 2011 - 03:39 AM.
#38 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 05 October 2011 - 06:49 AM
Just out of interest people im doing this with my chubby estate centre clock so dash rails ect how do you go about the switches like headlights ect and i think if i can't find a solution im gonna nick analague_radio idea with the mk1 switch panel just one question are you actually gonna use that ignition on the dash raIl instead of on column
Danny
#39 mini-adam
mini-adam
  • 79 posts
Posted 05 October 2011 - 12:38 PM
Restoring the clubby estate as well and preferred the look of having no dash rails and a centre speedo. So off come the padding filled in the fixing slots
Decided to change the standard switch panel for a row of flick switches with LED marker lights, so plated over the opening and smoothed off ready for careful drilling, keeping the centre ashtray, for loose change
#40 analogue_radio
analogue_radio
  • 4,897 posts
Posted 05 October 2011 - 02:04 PM
Danny
Yep I'll be using the ignition in the centre.
I'll have to disable the ignition in the column so it doesn't lock the steering.
#41 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 30 October 2011 - 10:06 AM
I think, a dashboard should look like this:
No padding on upper or lower dash rail, just a centre speedo (and possibly without the air vents, also)
Cheers,
Michael
what have you done to make the switch panel sit flush?
