Lower Dash Rail Removed - Switch Panel
11 replies to this topic
#1 orangeteg
orangeteg
  • 127 posts
Posted 18 April 2010 - 07:29 AM
i want to paint my lower dash rail the same colour as my car, it used to have that leather rail on it which i removed. My problem is the center switch panel. With the leather rail on it used to be 1-2cm away from the rail kept with brackets so it could fit, now that i removed the leather rail i want to put the panel directly on the dash rail without those brackets. How can i do this? Anyone done it before?
#2 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 18 April 2010 - 07:33 AM
not sure i understand you the switch panel is meant to be sunk into the lower dash rail
#3 orangeteg
orangeteg
  • 127 posts
Posted 18 April 2010 - 07:39 AM
Its suposed to be sunk into the dash rail if i keep the leather dash rail on...I have removed it and i want to put it like the Mk1's. Thats how i want it but i am not sure how can i fix the panel to stay there clicky
#4 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 18 April 2010 - 07:41 AM
oh right i see well you will need to keep the dash rail in you could remove the leather and clean it up repaint and refit to gain that look
#5 orangeteg
orangeteg
  • 127 posts
Posted 18 April 2010 - 07:47 AM
this is how i want it. but this guy kept the brackets so i guess the panel looks way too out of the dash...
#6 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 18 April 2010 - 12:18 PM
remove the existing spacer brackets and make some new ones up shorter ??
#7 RobG295
RobG295
  • 383 posts
Posted 19 April 2010 - 05:22 PM
Thats what i've just done...made up some small plates with a a hole either end that bolted to the choke/heater cables and the original holes for the mounting brackets. I think the holes were about 1" apart...but i'd check it first as i'm not 100% on it!!
#8 davejf
davejf
  • 280 posts
  • Local Club: CV1 and Central Minis
Posted 19 April 2010 - 05:59 PM
Thats what I did on my old car. The switch panel then sits over the hole. It's the easiest way.
If you want it to be more like a MK1 where the panel comes through from the back, then you can make up a new plate that bolts to the two original mounting holes, then modify the chrome surround to fit the smaller hole and it will stick through from behind.
Dave
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 April 2010 - 06:03 PM
Have you not noticed that the hole in the dash rail on cars built with the vinyl crash pad is much, much larger than the switch panel? Mk1 Minis had a smaller hole there. The panel you have now won't cover it. Apparently the panel from a pickup or van will fit, you might have to drill new holes and the switch arrangement will be wrong though.
#10 davejf
davejf
  • 280 posts
Posted 19 April 2010 - 07:13 PM
The standard switch panel should "just" cover the hole, or at least mine did.
Also attached how mine is now, poking through from the back.
Dave
#11 WillMini
WillMini
  • 191 posts
Posted 20 April 2010 - 10:56 PM
I had that problem so I just went to a sheet metal store and bought and offcut of aluminum and cut it to fit. You can cut squares to fit the original switches, i did toggle switches because the real ones were broken and I liked the look.
#12 evansisgreat
evansisgreat
  • 1,096 posts
  • Local Club: Not yet
Posted 21 April 2010 - 01:29 PM
Just as an alternative, I thought I'd post this picture. I think it looks really good. Hope whoevers it is, they don't mind me posting.
