Spare Ecu
5 replies to this topic
#1 robtheplod
robtheplod
  • 960 posts
Posted 02 March 2010 - 08:16 PM
I've been looking on eBay to get a spare ECU that I can keep for my 1996 spi mini. They often quote numbers etc and I'm a little nervous getting anything that might not be compatible. What should I be aware of when look to get a spare??
ta!!
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 02 March 2010 - 09:07 PM
MNE101150 coded non Cooper
MNE101170 coded Cooper
MNE101050 uncoded non Cooper
MNE101070 undoded Cooper
Those are the most common (single plug) and its not a finite list, there are others.
if you are looking for a spare its only a matter of looking at the numbes on the ECU you have. However, if it is a coded unit, ideally you need the alarm box and fob that goes with it. There is the option to have the alarm and ECU recoded by a specialist, but that will be for a cost and its not exactly a straight swap if that is what needs to be done. The uncoded ECU will work where a coded ECU was fitted and the alarm/ first stage imobiliser will still function
Edited by Sprocket, 02 March 2010 - 09:08 PM.
#3 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 03 March 2010 - 02:06 AM
Sprocket,
is the Japanese Minis with aircons have their own serial number? Also do you know the ECU numbers for Japanese SPi and Japanese Distributorless engines?
TA
#4 mrslaphead
mrslaphead
  • 362 posts
Posted 03 March 2010 - 08:16 AM
Sprocket,
TA
If you look on somerford minis website in the electrical section there is a list of ECUs including some with jap spec.
(Sorry not good with links, does this work )
http://www.somerford...x...=page&id=76
#5 Aria Aradhea
Aria Aradhea
  • 563 posts
Posted 03 March 2010 - 04:28 PM
Ah... right!
Thanks for the link!! <_<
#6 robtheplod
robtheplod
  • 960 posts
Posted 03 March 2010 - 10:54 PM
thanks sproket, so i would be looking for a MNE101050 uncoded non Cooper ??
