Rear Disk Brake Setups To Fit Under 13's
Posted 10 February 2010 - 10:31 AM
ive heard of a few setups that are used, including golf mk2+3/polo setups, sierra calipers being used etc.... Does anybody know what rear calipers and disks are used on the zcars kit !?!
Any help would be fantastic !
Sean
Posted 10 February 2010 - 03:05 PM
a friend of mine have explain this conversion in his build diary
http://www.16vminicl...e...7398&page=5
i hope that can help you
Posted 11 February 2010 - 09:18 AM
Not got much to add with regard to your question though sorry, as I think I'll be on wilwoods..
Having said that though, deendent on piston diameter matching etc, those yaris ones from the thread above do look neat enough - if the cable run can be sorted. Maybe a bit heavy though being cast...
Edited by SukiDawg, 11 February 2010 - 09:23 AM.
Posted 11 February 2010 - 02:05 PM
Posted 11 February 2010 - 02:16 PM
It's possible using a limited range of 13" wheels to fit the entire standard sierra disc setup which is what I have done
David
Posted 11 February 2010 - 02:29 PM
I'm waiting for the ' you only need disks from an airfix model and calipers off an under 3's tricylce, because the back of a mini floats away if you dont carry bricks ' response.
I'm very very impressed with the clio / toymotor solution and is making me re-consider my Mk2 golf ideas.
Posted 11 February 2010 - 08:52 PM
roofless i did take a look at the mk2 golf route to and seemed a good viable option, but like you say the clio/yaris combo looks a gooden:thumbsup: however so does the sierra/fiesta arrangement, afterall it has been tried and tested many a time on the zcars kit.
i would still like to go inboard ideally as i think it would look a little different and be quite a nice touch, however i think going that route could wind up being expensive (having to buy a single pot handbrake of some sort). hmmmmm will have to see what sort of money i can save up.
cheers for all the help lads
Posted 12 February 2010 - 09:05 AM
david, cheers for the info on the zcars set up, i thought they looked like sierra calipers, i think possibly from the xr4x4, xr4i or cossey models but very usefull to know what disk they used to! cheers mate. Do you recon they just made up there own backing plate for it ?
They are indeed from the higher end sierra, most of the lower spec sierras use drums. When you say backing plate do you mean the hub/bearing assembly? It is the standard sierra bearing carrier machined to remove the bolted area including disc mount, then this is welded to there trailing arm and custom brake caliper mounts welded to that to suit the smaller diameter fiesta escort discs used. There are many variations using drum hubs etc and using disc brake outer assembly and lately I believe they use Mondeo stuff, point is whatever they use is not a nut and bolt solution it requires modifications
David
Posted 12 February 2010 - 10:24 PM
Posted 13 February 2010 - 10:10 AM
Dont forget to use the locostbuilders site - wealth of help there if your stuck.
Good luck
Posted 15 February 2010 - 12:09 AM
Posted 24 February 2010 - 03:38 AM
Posted 24 February 2010 - 11:35 AM
Does anyone know which model yarris has rear discs?
Luke.
Posted 24 February 2010 - 11:57 AM
