'95 Mini Cooper Spi, Won't Start
Posted 16 July 2009 - 06:33 PM
Year:1995
Hi all, sorry this has to be my first post, but we have an urgent problem with my girlfriends '95 cooper.
She drove to work fine today, no probs with it at all. But when trying to start it to leave work this evening it wouldn't start. No cranking nothing. All lights work on dash, door switch e.t.c. ok. Immob light seemed to switch off fine and do as it should. She works at a garage but they weren't able to get a look at it before closing, and probably wont tomorrow, but they did check the starter which tests fine for voltage and doesn't appear to be stuck. They suggested the immobiliser was throwing a fit and refusing to work. Could this be the cause?
She has an aftermarket radio in and recently this seems to be having a few issues with the faceplate lighting going on and off over bumps, music still plays though. I'm wondering if, becuase the immobiliser box is behind it, something could have rubbed or got caught.
Also how about the relay pack? I've read something about that on here when searching, but not sure if it could be causing this problem.
We could really do with some advice asap as it's currently at her work place, but we will need it this weekend as I wont have my van. Also I know no one will tell me how on an open forum, but there must be ways of getting round it without paying a rip-off alarm company for it?
Thanks for any help!
Martin & Emma.
Posted 16 July 2009 - 07:00 PM
Posted 16 July 2009 - 07:08 PM
or the inline fuse behind the air box brown and purple (I THINK)
Posted 16 July 2009 - 08:42 PM
We're in east sussex, so unfortunately soton's a bit of a drive, thanks for the offer though
Posted 16 July 2009 - 09:17 PM
thanks guys, will have a look see and see what I can find tomorrow. It's the two button alarm so will check MiniMail and see what we can do after the cut off switch e.t.c.
Are you saying that it does not crank over? If so, then check fuse no 12 in the fuse box, it does the starter signal. Could be its blown. If so, replace it see if it works. If it blows again you might have a wiring short somewhere. if the immobiliser light goes off then it seems unlikely its the immobiliser.
Posted 16 July 2009 - 09:33 PM
Posted 17 July 2009 - 09:08 AM
nope, wont crank over at all. thanks for the fuse referance, will give that a go too.
Its what happened to my 95 Sprite. The fuse was corroded to hell and a new fuse fixed the problem.
It cuts out now and then because i really need to replace the fuse holder too, but its gettign round to doing it.
Posted 17 July 2009 - 12:34 PM
Posted 17 July 2009 - 12:43 PM
fuse seems to be ok. the mechanics at her garage have checked a little more and say that the problem is coming from a wire from the relay pack...does this mean anything to anyone? is there an immobiliser relay in there?
relay pack may need replaced.
you could try and open it up and clean the solders but that could break the waterproof seal.
Posted 17 July 2009 - 12:52 PM
Cheers!
Edit: Which of the below relays (if any) would it be?
Ta!
Edited by MartinSPI, 17 July 2009 - 01:13 PM.
Posted 17 July 2009 - 03:49 PM
thats what its generally refereed to
Posted 17 July 2009 - 05:45 PM
Thanks for all the help guys, been invaluable!
Posted 22 July 2009 - 09:10 AM
We replaced the relay pack ata cost of £100 from minispares. Worked fine for a day then blew this morning again. We'v got another on order, but I'm thinking a wire is shorting somewhere and pulling too much current. It seems to work fine for a few starts, then just blows.
Any ideas on which wire where could have worn through?
Cheers!
Posted 22 July 2009 - 01:17 PM
the joys of this continue!
Cheers!
Inline fuses behind the air box.
there is alot there and some could have shorted along the cable a bit.
Also check the alternator hasnt eaten some of the front cables and creating some sort of short there. I doubt it would but check anyway.
Also remove all the yellow relays and clean them up and put them back
Edited by BGB, 22 July 2009 - 01:17 PM.
Posted 22 July 2009 - 01:43 PM
I found an explanation on here about the relay pack and the wiring for it. One of the wires which feeds one of the relays is fed from the alarm ECU in the dash. We fitted a new radio which the alarm ECU seems to knock against...I would imagine that the cables could have got pinched and possibly rubbed through. Will be looking into tonight.
Thanks again BGB, will keep this post updated.
