Can Anyone Identify This Engine Number?
12 replies to this topic
#1 philsford
philsford
  • 103 posts
  • Local Club: BMC
Posted 19 May 2009 - 08:23 PM
As title can anyone identify this. 12H 298F 1159
could do with knowing what model it came out of.
#2 nicksuth
nicksuth
  • 1,631 posts
Posted 19 May 2009 - 08:34 PM
Have a look here................
http://www.theminifo...showtopic=81929
#3 philsford
philsford
  • 103 posts
  • Local Club: BMC
Posted 19 May 2009 - 08:43 PM
unfortunatly it is not on that site.
Anymore?
#4 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 19 May 2009 - 08:57 PM
clicky
found this tooclicky 2
not sure how much use they will be though im afraid
Edited by shorty, 19 May 2009 - 09:00 PM.
#5 philsford
philsford
  • 103 posts
  • Local Club: BMC
Posted 19 May 2009 - 09:30 PM
That last one is quite good 12h means its a 1275gt or mk3 s or a mk3 1300gt but the 298f is not mentioned which if info is available surley would tell me what car it came from. Or am I wrong?
#6 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 19 May 2009 - 09:34 PM
The 12 simply means it's a 1275 - the H means it's transverse....
It's the rest of the code that does the interesting stuff.
#7 newdawn1st
newdawn1st
  • 1,268 posts
  • Local Club: Fylde Mini Club
Are you sure that's the number, looked at mine recently and had to clean up the plate quite a bit before i could read it correctly. sorry don't mean to go for the obvious but worth eliminating it first :thumbsup:
edit: aside from that I can only suggest pm'ing guessworks on here?
Edited by newdawn1st, 19 May 2009 - 09:35 PM.
#8 philsford
philsford
  • 103 posts
  • Local Club: BMC
Posted 21 May 2009 - 08:21 PM
The number has definatly been read correctly.
#9 newdawn1st
newdawn1st
  • 1,268 posts
Posted 21 May 2009 - 09:11 PM
well thats me out of ideas :withstupid: :(
#10 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 21 May 2009 - 09:18 PM
so still no luck with it then?
have you tried PM'ing GuessWorks?
#11 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 23 May 2009 - 12:52 AM
298F = Lucas C40 dynamo, S type design variants, Close ratio remote control gearbox, Carburettor crankcase ventilation and twin carbs.
It is NOT a Cooper S engine, its from an MG 1300, Riley 1300 or maybe early 1300GT.
#12 philsford
philsford
  • 103 posts
  • Local Club: BMC
Posted 23 May 2009 - 09:40 PM
62S that is about the best suggestion yet. I couldn't find anything on 298f.
The gearbox and head are mk3 cooper s and I can only imagine that the block was damaged beyond repair and this alternative was sourced. It is now running a weber 40 instead of the twin carbs.
#13 62S
62S
  • 1,243 posts
Posted 25 May 2009 - 11:22 AM
The later MG 1300, Riley 1300 and 1300GT used the same cylinder head as the Mk III S.
