Electric Fuel Pump Fitting
3 replies to this topic
#1 gregster
gregster
  • 46 posts
  • Local Club: no
Posted 21 March 2009 - 05:40 PM
Hi all, has anyone got any advice on fitting an electric fuel pump (how to guide) or which pump set up to use ?
Thanks in advance !
#2 m1n1
m1n1
  • 747 posts
  • Local Club: I'm unsociable
Posted 21 March 2009 - 06:46 PM
not as such,, i just had a low pressure solid state facet pump lying around so i drilled and bolted in onto the inner subframe just below the outlet pipe of the tank. Easy peasy, and ran the wiring inside the car under the carpets and exiting the boot area just above the pump.
#3 fishey798
fishey798
  • 562 posts
  • Local Club: Mini Rebels
Posted 22 March 2009 - 11:28 AM
I did the same as m1n1, i do have a couple of pics but they arent brilliant. I also fitted a inertia switch incase of an accident.
Also i have a fuel pressure regulator fitted in the engine bay
And this diagram gives you some sort of idea of how to wire it all up
#4 gregster
gregster
  • 46 posts
  • Local Club: no
Posted 22 March 2009 - 08:23 PM
Cheers fishey,
top plan,
wiring diagram for inertia switch is the one i wanted
Saves me setting fire to my car !
