Nitrous Oxide Kit
Posted 22 August 2005 - 11:36 AM
Just out of interest, has anyone ever fitted a Nitrous Kit to their Mini?
I'm thinking about it as a trackday toy, and want to find out about the practicality, cost and difficulty in doing this.
Any help would be greatly apreciated....
Cheers,
Will
Posted 22 August 2005 - 11:48 AM
With myself and a friend it took an afternoon from start to finish!
Basically you bolt the bottle into a suitable location (usually in the boot) run the pipe from the bottle to the inlet manifold. The kit I used (nitrous express) had a single wet injector. Take a feed from your fuel line into a solenoid controlled valve, the feed from the nitrous bottle to the other solenoid controlled valve the outlet pipe from each one to the injector (it also mixes the two) and mount the injector firing into you inlet manifold (on my old car this was after the air filter basically used a short length of drainpipe).
You then wire a switch to arm it, a microswitch on your throttle linkage to fire it on what (this opens the two solenoids) and hey presto you off and running very swiftly! :grin:
Just don't go mad!! I would suggest 50Bhp jets at the most! Unless your uprating the internals! :nugget: :grin:
Posted 22 August 2005 - 11:50 AM
Posted 22 August 2005 - 11:58 AM
Your engine should be fine unless you go over the top! The old nitrous systems used to be very lairy because they just injected nitrous and you had to change the timing to add more fuel! If you forgot, you'd run ridiculously lean and bang! no engine.
The newer systems use fuel injected with the gas to stop this from happening. So you don't need to adjust anything just fit and go! :grin: In a lot of cases the inlet charge is so much cooler it actually reduces the wear on you engine compared to normal!
The only thing you need to remember is to show it some respect! Don't go thinking you can dump the throttle at 1200rpm without straining the engine you need to allow the engine to at least get moving before you start adding all the extra power.
Also don't forget to fully tighten any pipes before opening the bottle outlet! Nitrous gas is VERY cold!!! And will give you a cold burn!! I can tell you it really stings and nothing soothes it! Cold water hurts warm water hurts not doing anything hurts! It's a bit of a bummer! :nugget:
Posted 22 August 2005 - 11:59 AM
Was thinking of running two 20bhp jets, one on each side of the inlet manifold to try to get the best distribution possible with the mini inlet manifold!
Dave
Posted 22 August 2005 - 12:04 PM
Personally I think for fast road/occasional track use at most you'll want a single injector with a bottle warmer. (being a gas as soon as you start to discharge the bottle it'll get colder and therefore the pressure will drop thus losing power the heater will stop this) two injector won't make a massive difference to be honest. The single jet I had was very well dispersed (if you fired it into the air you got a very good idea). :grin: :grin:
Posted 22 August 2005 - 12:16 PM
http://www.noswizard.com/
(the only company that adrian flux will insure)
ignore people with the "your engine will get knackered" comments. its possible but only if it is installed wrong or abused in use.
Posted 22 August 2005 - 01:07 PM
Posted 22 August 2005 - 01:13 PM
Posted 22 August 2005 - 01:25 PM
Posted 22 August 2005 - 02:00 PM
I'm not too worried about the engine / box, because it cost me under £100 out of a crashed MG Metro. As long as it doesn't kill the Nitrous Kit when the engine goes bang then i'll be : )
Have been looking at some kits online, and all things considered, Minispeed's kit looks reasonable. Has anyone got any thoughts on this?
can't wait to able to go fast on the straights as well as the corners!!
Will
Posted 22 August 2005 - 03:36 PM
Posted 22 August 2005 - 04:32 PM
(i have not done a mini , only a focus)
but adding 50% in one lump is a lot for the engine internals , better to fit a 2 stage injection 25bhp + 25bhp , you add 25bhp with the what switch and then another 25bhp on a button .
there is no need to buy an expensive kit all the bits can be bought seperatly for about £100 all in
Do a search on: diy nitrous oxide injection
the site is run by Burgerman
I will post a link if i can find it (cant find much since new hard drive fitted )
Posted 22 August 2005 - 04:40 PM
Posted 22 August 2005 - 04:43 PM
