Nut Cap
5 replies to this topic
#1 Dave H
Dave H
  • 50 posts
Posted 30 August 2008 - 08:05 PM
have been to the garage today to get my wheels balanced and have been informed they can't get the wheels off as a couple of the nuts have caps over that are stuck!
The guy said rover had a special cap removing tool for this and i need to get one as they don't want to use a screwdriver to prize them off.
does anyone have any info on this as it seems odd to me.
Dave
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 30 August 2008 - 08:11 PM
if you're on about the tinny metal things on the nuts used on alloys, they are meant to be there and rarely come off.... they just need the right sized socket...
they've obviously just used an air gun on them and spun them...
Edited by GuessWorks.co.uk, 30 August 2008 - 08:21 PM.
#3 AshW
AshW
  • 488 posts
  • Local Club: Bumpstart mini club
Posted 30 August 2008 - 09:39 PM
all the local garages always do this to the wheelnuts an on rover alloys, and i keep buying new ones
#4 newbambeeno
newbambeeno
  • 360 posts
  • Local Club: None
Posted 30 August 2008 - 09:58 PM
If it is the nut caps spinning then there is a way of getting them off. I did this on mine and although I was nervous doing it, the nuts seemed fine underneath afterward.
Get a small screwdriver or autopunch (for spot weld drilling, i think there about £3 at Screwfix) then punch a hole in the middle of the cap and then use an old screwdriver the split the cap all the way to the edge. The cap should be easy to pull off from here.
Hope this helps
#5 Dave H
Dave H
  • 50 posts
Posted 30 August 2008 - 10:09 PM
Hope this helps
Sounds like a good idea thanks.
you would think a tyre place would have this sort of idea wouldn't you!
Dave
#6 woody17
woody17
  • 432 posts
  • Local Club: three valleys mini club
Posted 31 August 2008 - 06:45 PM
the idea they wont use a screwdriver is because they will damage the caps.
what they need is a plastic tube thing (usually with a yellow sticker on) to remove the caps.
there should be one in some jack bags, but most people loose them.
