Rear Door Cards/trims
Posted 08 August 2008 - 09:19 AM
Is it just a case of forcing them out because they just seem to be jammed in there. Are there clips on the back?
Ant.
Posted 08 August 2008 - 09:32 AM
Posted 08 August 2008 - 10:14 AM
Posted 08 August 2008 - 10:44 AM
You have to take the bottom out the rear door bins (the cardboard bit at the bottom!) Then try and slide the card down a bit, then pull it out. Its only attached under the rail along the top
Yeah cheers pal will do.
Posted 08 August 2008 - 10:45 AM
You'll have to take off all the door furniture first, then prise the panel off the door at the bottom.
Thanks but I did specify rear.
Posted 08 August 2008 - 03:18 PM
really difficult to get out it think.
easy to put new ones in!!!
good luck
Posted 08 August 2008 - 03:20 PM
Posted 08 August 2008 - 03:29 PM
Doh, really need to read thing through first..... so soz
Posted 08 August 2008 - 04:57 PM
Posted 08 August 2008 - 07:37 PM
Posted 09 August 2008 - 12:28 PM
If your having trouble putting new ones in bend them (gently!) over your knee. This will effectively shorten them and they'll slide in no probs
Thanks for the advise.
