Mini Arm Rests.
Posted 24 January 2010 - 11:07 PM
Thanks.
Posted 25 January 2010 - 04:01 PM
Posted 25 January 2010 - 06:50 PM
Posted 25 January 2010 - 07:33 PM
Posted 26 January 2010 - 05:54 PM
Posted 27 January 2010 - 06:25 PM
Posted 27 January 2010 - 07:14 PM
Sam
Posted 27 January 2010 - 07:17 PM
i'd be temped to bolt it down, i know i'd rather it be bolted securely than it becoming a missile during a crash.
Sam
if you do that will you still be able to move the seats to get in the back?
could you not use the plans (there around here somewhere) and just make it a little wider so its a tight fit and does'nt move?
Posted 28 January 2010 - 10:10 AM
Sam
The fixing of the item is something we are having trouble with - and we wont be selling the item unless we can attach the arm rest into place.
As has been mentioned (briefly) if you move your front seats - or even simply raise the back to let people in the back - the arm rest moves and quite simply, it shouldn't.
Posted 28 January 2010 - 11:09 AM
Its the best purchase i've made. Makes journeys much more comfortable.
Mine is held in place by friction. its made to be 'wedged' between the seats and squishes out at the bottom, so its quite a snug fit.
But you do have to pull it out if your moving the seats but that hardly happends for me
I could go out and take a picture of how it sits if anyone likes.
Posted 28 January 2010 - 04:21 PM
I like my armrest, but then it is up to you if you would like one in your mini too . Hope the picture's help.
Posted 28 January 2010 - 06:46 PM
i'm tempted to make one up of my own if they fit, in fiberglass (just fiberglass not mdf covered in the stuff.)
with some little tabs to bolt it where the seatbelts bolt in.
sam
Posted 28 January 2010 - 06:57 PM
Posted 28 January 2010 - 08:11 PM
then have each side attach seat which it is up against, that way it will move with the seat, (if that makes sense?)
its probably not even possible
