Top Dash Rail
13 replies to this topic
#1 mini_1275
mini_1275
  • 23 posts
Posted 05 January 2010 - 01:53 PM
hi everyone im after some advice on removing my top dash rail?
#2 wakkoboi
wakkoboi
  • 414 posts
Posted 05 January 2010 - 01:56 PM
IIRC there are screws on the top but i think you need to take the front windscreen out
#3 chrisgonz1
chrisgonz1
  • 186 posts
  • Local Club: Purely business!
Posted 05 January 2010 - 02:01 PM
I remember i had to stick my hand through the back of the dashboard (if you have one fitted) and unscrew 3 nuts. left, middle and right. not easy to get to. may be worth removing dash if you have one. then should just pop out.
This is how i did it but that doesnt mean i am right so please dont attempt it without hearing from more people.
#4 wassupcrew
wassupcrew
  • 502 posts
Posted 05 January 2010 - 02:12 PM
as above. its the right way. undo the theree nuts and you can lift it out. its tight with the windscreen in though but can be done with patience
#5 1995 MK2 IOM
1995 MK2 IOM
  • 810 posts
  • Local Club: NO CLUB HERE.... YET
Posted 05 January 2010 - 06:10 PM
as above - pretty tight with the center bolt - few cuts on hands but nothing more than expected with the mini...
#6 petwar
petwar
  • 241 posts
Posted 05 January 2010 - 06:30 PM
you dont have to remove the screen to get the dash out. Its just the three bolts.
#7 BlakeMcCall
BlakeMcCall
  • 84 posts
Posted 05 January 2010 - 06:46 PM
i couldnt get it out with the windscreen. In the end i used a dremel to cut the bolts a little shorter while it was in then it just came out easy.
#8 The Orange
The Orange
    Just On Tickover
  • 9 posts
  • Local Club: Mini Club Aarhus
Posted 05 January 2010 - 10:58 PM
I got it out without the windscreen also, but I've tried to take it out with the windscreen in, and with a little fiddeling it can be done.
Often there is only 3 nuts to losen. In mine there were 4...
#9 joecowan
joecowan
  • 128 posts
Posted 12 January 2010 - 04:24 PM
hey. im trying to do this but i cant get to the bolts that are above the air vents. how do get to these. also how do i take the vents out if needed
#10 captainjack15
captainjack15
  • 3,925 posts
Posted 13 January 2010 - 11:35 AM
So it really is that easy?
Because I need to do it!
#11 leaky
leaky
  • 6,890 posts
Posted 13 January 2010 - 11:54 AM
Mines not even bolted in. Mine seems to stay in place fine. I just give it a whack and it pops out. Takes a sew seconds.
#12 chrisgonz1
chrisgonz1
  • 186 posts
Posted 13 January 2010 - 12:00 PM
Hah like my dads! blooming cowboys! :dontgetit:
#13 captainjack15
captainjack15
  • 3,925 posts
Posted 13 January 2010 - 04:56 PM
Oh dear :dontgetit:
So there is a bolt in the middle? And two and each end? Because the one in the middle is fairly long isn't it!
#14 rich1889
rich1889
  • 285 posts
  • Local Club:
Posted 10 February 2010 - 02:24 PM
All i did was undo the 4 nuts and hit each bolt with a hammer done
