Firing Order With Megajolt
38 replies to this topic
#1 Sammy D
Sammy D
  • 977 posts
Posted 13 August 2008 - 03:27 PM
1 - 3 - 4 - 2. Everyone knows that.
However, on the coil pack there is 1, 2, 3 and 4 printed by the leads.
So am I right in thinking that on the coil pack...
1 = #1 cylinder
2 = #3 cylinder
3 = #4 cylinder
4 = #2 cylinder
#1 cylinder being water pump end.
Why am I only firing on two cylinders then?
Arg!
#2 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 13 August 2008 - 03:47 PM
Coil packs wire up as per the numbers
1>1
2>2
3>3
4>4
#3 Sammy D
Sammy D
  • 977 posts
Posted 13 August 2008 - 03:52 PM
Are you sure??
Because it didnt seem to want to work at all that way :s
#4 Ethel
  • 25,909 posts
Posted 13 August 2008 - 03:59 PM
the numbers will refer to the plugs if you've wired up the LT connection to match. There are only 2 firing "events". 1+4 & 2+3. If you're getting sparks just swap one pair over with the other.
#5 Sammy D
Sammy D
  • 977 posts
Posted 13 August 2008 - 04:19 PM
Sorry I'm confused. Do what? What's the LT connection? Swap what and what?
#6 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 13 August 2008 - 04:59 PM
Its wasted spark so the coil pack fires in pairs 1+4 & 2+3
Either swap the 2 outside low voltage wires to the coil pack or swap ht leads 1&4 with 2&3
If your only firing on 2 cylinders, which ones?
Possible cause of 2 cylinders is one of the trigger wires to coilpack not connected, one side of the coil pack has died
Edited by ratty, 13 August 2008 - 05:00 PM.
#7 Sammy D
Sammy D
  • 977 posts
Posted 13 August 2008 - 05:04 PM
I'l try swapping the leads.
So put the current leads that are on coil pack 1&4 to 2&3. So swap 1 to 2 and 4 to 3 basically?
#8 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 13 August 2008 - 05:10 PM
yup, if its only firing on one bank ie 1&4 swap the low voltage wires on the coilpack over, if the other bank fires the coilpack is working and the fault is in the trigger wire
#9 Sammy D
Sammy D
  • 977 posts
Posted 13 August 2008 - 05:16 PM
Ok, il give it a go... right now....
Low voltage wires... what are they. Sorry haha, I just wired up up knowing them as wires 1 2 and 3 from the diagram.
#10 Sammy D
Sammy D
  • 977 posts
Posted 13 August 2008 - 05:32 PM
Ok, swapped the leads. Got it started after a LOT of jump leads, choke, general effort. It's still firing on two cylinders though.
This is REALLY REALLY anoying me now.
What's next?
#11 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 13 August 2008 - 06:17 PM
possible dodgy coil or EDIS unit. check your wiring.
#12 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 13 August 2008 - 06:52 PM
Make sure the pip and saw wires are the right way around (although they can be disconnected for testing), and the crank trigger wires
Then
To check the coil pack
Run the car and check which pair is firing then let us know which
Swap over coil A and coil B wires (1&3 on the coil pack)
Then run the car again and report back which plugs are firing
Edited by ratty, 13 August 2008 - 06:54 PM.
#13 Sammy D
Sammy D
  • 977 posts
Posted 13 August 2008 - 07:05 PM
Right ok, so should I test this with the pack in;
1 = #1 cylinder
2 = #3 cylinder
3 = #4 cylinder
4 = #2 cylinder
or
1>1
2>2
3>3
4>4
Thank you for all your help by the way!!
#14 Guest_ratty_*
Guest_ratty_*
  • Guests
Posted 13 August 2008 - 07:11 PM
I'd go 1>1 2>2 etc so it makes any diagnosis easier later on but as long as you consistant it should really matter
To start with remove plugs 1 & 3 from the head and see if you have a spark on both
#15 Sammy D
Sammy D
  • 977 posts
Posted 13 August 2008 - 07:12 PM
Brill, going outside now...
