Mini Sport do 3 size's of alloy callipers, 7.5 which fit onto the cooper s type hub and drive flange and use the cooper s disc's, and also they make vented/non vented 7.9 callipers, these use the original 12" hub assembly and drive flange and just use a turned down disc (8.4" solid/vented) which fit's in the same was as the stock disc's do originally and also they make 8.4" (just finished the 3 sets of samples) at the moment these are just in vented but im unsure whether these are going to be also available in solid disc form......
The 7.9 callipers shouldnt foul on the callipers as they have a machined edge to keep them as far away from the wheel as possible but do check with them before placing your order.
Edited by Southy, 04 March 2008 - 08:38 PM.
