Nissan Micra Engine Transplant
Posted 08 September 2007 - 02:42 PM
Posted 08 September 2007 - 02:56 PM
How do you do the driveshafts?
Posted 08 September 2007 - 03:00 PM
Posted 08 September 2007 - 03:04 PM
Posted 08 September 2007 - 03:14 PM
Posted 08 September 2007 - 03:19 PM
well heres how easily we fit the nissan micra MA10 5speed to the mini.
wow! you make that look easy - I'll bet this isn't the first one you've done eh?
my buddy at work is from Martinique and he has often told me that micra's out there become donors for all kinds of things - what sort of power can you get from Micra running gear?
Posted 08 September 2007 - 03:21 PM
Posted 08 September 2007 - 03:27 PM
[/quote]
after mounting the engine cut the four half shafts to an arbitrary length(two nissan inner, two mini outer)
slide nissan inner cv joint halfway into its drivecup and mark where both shafts line up against eack other. repeat on the other side. then take apart cv joints, line up the marks uve made and measure with measuring tape. on the micramini the left is 13inches, the right is 22 1/2 inches.
take it to the machine shop wher they match the diameters of both the jap and uk shaft.
both shafts chamfered 45 degrees and welded on the lathe. an additional stainless steel sleeve is slid over the shafts and welded in. othe r machine shops may just chamfer and weld using a titanium or special rod and its guaranteed not to snap!
Posted 08 September 2007 - 03:38 PM
[/quote]
its a 1000cc engine, about 55 or 60hp without the cat. the intake and carb is really weird, it goes away from the engine then towards it in about 14 or 16 inches! hence great low end torque but could be really zippy i guess with some side drafts and 4 2 1 headers as its crossflow head.
Posted 08 September 2007 - 07:21 PM
(very dodgy paint picture alert!)
Cant help but think that a decent inlet could release SO much more potential on the engine!
Posted 08 September 2007 - 08:50 PM
My brother had a micra with this engine, it took abuse all day long everyday for a loooong time and just seemed to get faster and faster and never gave up!
Good stuff.
Posted 08 September 2007 - 09:02 PM
hats off to you guys it looks like a very good job you have done there
Posted 08 September 2007 - 09:17 PM
what i'm getting at is would it be easy to convert a regular 1990 engine to that spec...
cheers for any reply
warren
Edited by CanadianMiniFan, 08 September 2007 - 09:32 PM.
Posted 08 September 2007 - 09:21 PM
could webers go on quite easily/with some mods...?
Posted 08 September 2007 - 10:54 PM
by the way, that's quite an ingenious setup you're using for the brake servo. Was that something you done just for this conversion, or is that a fairly common mod in your area?
10 user(s) are reading this topic
0 members, 10 guests, 0 anonymous users
