C-Shape Washer Behind Flywheel
Posted 17 December 2011 - 04:30 PM
Can anyone show me what the c-shape washer behind the flywheel looks like? I 've tried to pull mine off with a pulling tool but have not taken the c-shape washer in consideration. How easily would one wreck this washer resulting in not ever going to get the flywheel off? The engine is brand new so it's not like it's been stuck for years. I know there is a lot being written about flywheel removal, but even with the old topics I can't seem to get it off... I'm a bit desperate to find out whether I've already done some harm...
Jelle
Posted 17 December 2011 - 04:45 PM
Edited by Jellevandok, 17 December 2011 - 04:46 PM.
Posted 17 December 2011 - 04:48 PM
Somebody will confirm but I think you need No 1 cylinder (nearest radiator) to be at TDC before trying to pull flywheel off
Posted 17 December 2011 - 04:49 PM
the c washer can only move once you have used the flywheel puller. if you have the crank in the wrong position, use the puller, and th eflywheel pops off, the washer can only move then and stop the flywheel coming off.
Posted 17 December 2011 - 04:59 PM
if the flywheel is still on, and the crank is in the correct position (judged by the position of the slot in the end of the crank nose) then the c washer cant slip down and jam the flywheel on.
I'm sorry. So how can I see if the crank is in the right position? Is there a marking somewhere? Or is it ok when the sleeve in the crank is horisontal ether way? I've already tried pulling it and it didn't move an inch. How stuck are those flywheels on there? How big is the chance that I've wrecked the washer and killed my project? Or will I still be able to remove the flywheel without harm done?
Jelle
Jelle
Posted 17 December 2011 - 05:10 PM
Posted 17 December 2011 - 05:16 PM
As for how tight they are, the answer is anything from not tight at all to very very tight. All depending how long it's been on there.
When I removed the flywheel from my 998, the amount of force I had to apply with the flywheel puller caused the fly wheel to jump off the crank. You've got to be cautious when removing them.
If you are worried. I found this image on Mini Spares:
You can see the slots for the C washer are horizontal when the crank is flat. If you move the pistons so they are all mid stroke, the C washer shouldn't be affected by gravity. This is however assuming all cranks are made with the slots in the same orientation to the crank.
Posted 17 December 2011 - 05:20 PM
The position of your flywheel is correct, they don't go on any further than that.
Use a good quality puller and make sure you lock the flywheel with either a flywheel locking tool through the starter hole, or a suitable piece of steel jammed into the starter ring. For safety the proper flywheel locking tool is highly recommended.
Indeed, the C-washer holds the primary gear in place and after the flywheel is removed, you pull the C-washer out and the primary gear will come off the end of the crank once the primary gear inner oil seal is removed from the transfer gear casing.
Edited by Cooperman, 17 December 2011 - 05:21 PM.
Posted 17 December 2011 - 05:28 PM
Posted 17 December 2011 - 06:15 PM
Posted 17 December 2011 - 07:34 PM
The C-washer won't move until the flywheel starts to move and although in theory it can drop down and jam the flywheel, personally I've never even heard of this happening. I guess someone will be along to tell me it happeneed to them.
Anyway, turn the flywheel until the pistons are all at mid-point. Check this by taking out the plugs, if the head is still on, and putting a pencil down each bore. When the pencil goes the same distance down each bore till it touches the piston top then all pistons are at mid-point. If the head is off, you can see when all the piston tops are at the same distance down from the top of the block.
Lock the flywheel as above and apply high torque to the centre bolt of the puller. Increase this torque until the flywheel comes off. if you get it really tight and the flywheel is still on, get a big club hammer and hit the end of the centre bolt really hard as if trying to knock it into the crankshaft end. That normally frees it. If it doesn't just tighten the bolt a bit more and clout it again.
Posted 17 December 2011 - 07:38 PM
You need to use a proper puller, with the thrust plug fitted in the end of the crankshaft, or you will riun the thread in the crankshaft and have a very big problem. But right now, you don't have a serious problem.
Turn the engine till the pistons are half way down the bores (feel with a thin object throuigh the spark plug holes, or set the timing marks on the pulley end to 90 degrees approximately), put the puller on, tighten it up, and whack the back of the flywheel through the starter motor aperture. Tighten the puller again, whack it again, and eventually, with a loud bang it will be free.
Keep the crankshaft at the 90 degree position until the flywheel is off, then you can see the C washer, and remove it.
Posted 17 December 2011 - 07:44 PM
Just hit the centre of the puller centre bolt as that puts the shock load straight into the centre-line of the puller and crank which ius where you want it.
Posted 17 December 2011 - 08:08 PM
Good point about the Verto. The reason I never suggested whacking the puller bolt (as you often have to do with any type of puller, not just the Mini flywheel) is that there is no room to swing a hammer, and I have always done clutches etc in the car. But on reading more closely, I see that the engine is out, so that is feasible. Tighten, whack, tighten, whack..... It has to release eventually.
Posted 17 December 2011 - 08:20 PM
