Why Dose This Happen
Posted 26 November 2011 - 04:38 PM
Stuart
Posted 26 November 2011 - 04:41 PM
I could be wrong but I wouldn't think it had anything to to with an earth.
Posted 26 November 2011 - 04:46 PM
I'm too slow
Edited by Carlos W, 26 November 2011 - 04:47 PM.
Posted 26 November 2011 - 04:53 PM
If the battery voltage drops from about 12v to next to nothing when you turn on something like the headlights, then it has developed an internal resistance. The battery must be replaced.
If the battery voltage drops to less than 10V while cranking, the battery needs charging or it needs to be replaced.
If the battery voltage drops to no less than 10V while cranking but the engine does not start, the the battery connections and earth connections are poor. They must be cleaned or replaced.
Hope that helps,
Ivan
Posted 26 November 2011 - 04:59 PM
Posted 26 November 2011 - 05:07 PM
Posted 26 November 2011 - 05:18 PM
Put your battery on charge overnight if after charging the needle has not reached zero
give it to the scrap man
Edited by firefox, 26 November 2011 - 05:20 PM.
Posted 26 November 2011 - 06:17 PM
Posted 26 November 2011 - 06:25 PM
James
Posted 26 November 2011 - 07:03 PM
It refers to people with Down Syndrome!
If you were so clever you would know this
Posted 26 November 2011 - 07:50 PM
Topic closed while I try to sort this mess out.
Posted 26 November 2011 - 08:15 PM
Right, the topic has been cleaned up. Please keep it on topic.
Posted 26 November 2011 - 09:12 PM
