Retro Twin Cam Mayfair - A Proper Job
23 replies to this topic
#1 zebidee
zebidee
  • 444 posts
Posted 24 October 2011 - 09:33 PM
Finally my little car has moved from 'Mini Engined Projects' to 'Complete Mini Rebuilds'; the time has come when it needs to have a good chop and repair! After a long two years of being sat in my garage whilst I finished at University, it's now looking a little bit sorry!
When last on the road the car looked like this...
Which has become this (excuse the messy garage, I'm the only one who tidies it)...
So instead of just keeping it on the road bleeding money like I have been for the past while, I thought I would start from scratch and fully rebuild it. I'm going for a retro mk1 look (I would love a MK1 but simply cannt find a project to take on), and planning on doing a Specialist Components twin cam engine. I'm focusing on bodywork first, but hope to be on the engine by spring time next year. Ive been working on the car for the past couple of weeks but haven't got round to starting a topic, so there's abut of catching up to do! Onwards...
I stripped the car down to a bare shell 2 weeks ago to start looking at what really needed doing, including a nice rusty sill
A crusty boot
And some horrible sill strengtheners and rear subframe mounting points (on both sides :( )
#2 zebidee
zebidee
  • 444 posts
Posted 24 October 2011 - 09:34 PM
So, got the car to a bare shell
(tennis ball on the gear lever after I almost put it through my lung!)
Stripped out all the crappy wiring. After 24 years of being patched over and over again there wasn't anything left of the original loom, just hundreds of soldered joins, so a brand new loom will be going in. It was almost impossible to find any decent original parts under the bonnet!
All out! Yay!
Headlining out...really not looking forward to it going back in!
Then engine out time
Much easier than I thought!
Which left the shell looking decidedly empty, well, apart from all the rubbish I then dumped in it!
Bulkhead looks a bit rough, but it's mostly surface from when the carb float overfilled and poured fuel all over it!
#3 zebidee
zebidee
  • 444 posts
Last week I then got around to stripping the engine down
Bores looked like they were in good nick, but...
...liners, dang! I had planned on boring the engine out so this meant I would either need to source a new block or keep the current capacity. I'm undecided at the moment!
Intact, the whole engine was in pretty good nick, and I haven't really treated it kindly in the last 5 years! Nevertheless, no blown gaskets, no gear teeth, nothing but oil in the sump!
Crank all looked ok too
And then I had a pile of stuff to get rid
So all in all, it was an uneventful strip down, apart from the linered block, bit of a bummer! Currently that's where it's at. I have never welded before, but I'm going to buy a welder as soon as I can and then get to it! Bit daunting, but I just really fancy learning! More to come very soon!
#4 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 24 October 2011 - 10:36 PM
Very cool styled car but good luck with the Retro style! Rebuild of car and engine side by side. You sir are much braver than me! Im doing car first, engine after :lol: Too many bits to go missing!
#5 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 24 October 2011 - 10:47 PM
Looks great! Out of interest. What are you doing with the rocker cover ?
Dan
#6 grahama
grahama
  • 2,442 posts
Posted 25 October 2011 - 06:39 AM
How long ago was the first pic taken as it looks in mint condition there, such a shame it has to be re done, but will be worth it in the end I'm sure.
#7 lawrence
lawrence
  • 1,340 posts
Posted 25 October 2011 - 10:14 AM
Are you going the be replacing the wings and front panel too? as they look pretty mint but then again your scuttle closers could be gone like mine were :( looks like a great project tho!
#8 zebidee
zebidee
  • 444 posts
Posted 25 October 2011 - 04:37 PM
Thanks for the comments folks!
Thanks! I still love it but just fancy a bit of change, and I've always loved Mk1s just because its such a timeless look! Don't worry, I'm not that brave either :lol:, I just stripped it to see which bits I could reuse in the new engine. It's not so much losing bits, but the huge immediate cost would be a bit daunting :blink:! I found a couple of other pics of it in better days:
Dan
I'll be selling it along with most of the other bits and pieces from it's old guise, if your interested give me a PM! I'll be polishing it and touching up a few parts of the yellow before it's sold since it's just been sat around for so long :thumbsup:
Two and a half years ago, not long enough for how it looks now! It was before I was really too confident with being hands on and I took it to a bodyshop who didn't do the best job...looked great for a while but wasn't really a lasting finish! I sure hope it will be worth it!
I don't plan to, initially they look fine but, as you say, I think the scuttle closers and flitch panel may be a little past it (I'll get in with Mr. Stabby this week and have a prod). I'm torn between keeping the steel front or fitting a one piece carbon front (keeping the inner wings to avoid an IVA) at the moment too!
#9 zebidee
zebidee
  • 444 posts
Posted 25 October 2011 - 07:08 PM
A few parts I've been working on, initially for a different project I was collecting bits for but will now be used on this.
MK1 speedometer, ebay bargain at £6! Pretty awful condition, but stripped it apart, resprayed the body and touched up the face, cleaned the mechanism up and a bought a new bezel.
I did the same for the other gauges I had (does anyone know whether you can purchase a new glass for the rev counter with that redline included), and also have a water temp in the same style as the oil and vacuum.
I also have a 14'' Motolita wheel
Lucas dipping rear view mirror (this will be cleaned up, another ebay bargain!)
A pod for the rev counter (great part from Mark at MK1 Performance Conversions)
Butlers map light (no pictures of when I bought it, but it was beaten as well!)
#10 zebidee
zebidee
  • 444 posts
Posted 26 October 2011 - 02:20 PM
Since I don't yet have a welder (I'm planning on getting a Clarke 135TE) I have a lot of time with not many jobs I can get on with. Because of this, I'm taking ages doing things which shouldn't really take that long :lol: ! I guess it's advantageous just for the fact that I'm taking care over every little thing, though I do feel like I'm treading water a bit at the moment!
Since I'm planning on using the KAD internal shifter kit to take the gear change housing into the car I thought I would doll it up =] . The car is going to be somewhat comfortable, so I don't want it to be all function over form. Cleaned it up, primed, then sprayed with a wrinkle paint.
Pretty gross when it came off the car
Cleaner
Rubbed down
Primed
Finished
I've had mixed results with wrinkle paint before from following the can instructions (I was using Hycote), so decided to do things a little differently. If anyone is doing the same, try this:
I warmed up the part with a heat gun prior to spraying and used a large halogen work lamp to heat the area up. I then sprayed 4 coats with 5 minutes in between, each coat sprayed thickly to the point that anymore paint and it would run. After each coat I used the heat gun to evenly heat the paint (the first coat will probably not show any signs of wrinkling when doing this and will be very glossy, don't worry! Further coats will begin to wrinkle). By the second coat I began heating up my electric oven to 110ºC (make sure the oven is not on fan). Heating the part in the oven means you get well defined and even wrinkling. When the fourth coat was on, I let it sit for about 5 minutes before placing it on the middle shelf of the oven. I left it here for 30 minutes, then turned the oven off and left the part inside over night to cool down slowly with the oven. This worked out really well for me, whereas I've never really been happy with the finish that the can instructions give ^_^.
Close up of the finish
I hope that helps anyone doing the same!
#11 dean.austin
dean.austin
  • 212 posts
Posted 26 October 2011 - 06:39 PM
thats a real nice lookin paint scheame
#12 grahama
grahama
  • 2,442 posts
Hi,
Love that steering wheel, very retro, and the wrinkle paint is nice too but far too much hastle for my limited patience. Keep it up though and the result will be as it should have been from the bodyshop !!
Graham
#13 zebidee
zebidee
  • 444 posts
Posted 26 October 2011 - 07:34 PM
Thanks for the comments chaps!
Hi,
Graham
It was a bit more work than a normal finish but I do have too much time at the moment and can't get on with what I really want to, so wasting time is the name of the game! :lol:
#14 tedmcedd
tedmcedd
  • 2,751 posts
Posted 26 October 2011 - 08:40 PM
nice job on the guages, i love refurbing parts! its so satifying! that rev counter is a rare one going up to 10K... they are what the works cars used, more comonly seen in 8K form... I look forward to seeing how this goes!
good luck with it all!!
ED
#15 zebidee
zebidee
  • 444 posts
Posted 26 October 2011 - 09:13 PM
ED
Thanks Ed! Completely agree! There's something massively rewarding about it! I use to buy dead gauges, fix them up and sell them on ebay, it's nice to actually keep the result!
I know, I've only seen a few and took a while before I found one that I could actually afford! It's been freshened up like the others but I'm having problems sourcing a new glass for it (well, plastic really) with the redline included. Don't really need the whole glass, but I think it will be impossible to paint the redline as it is :ermm:.
