L_jonez Micra Build
406 replies to this topic
#1 l_jonez
l_jonez
  • 1,453 posts
Posted 05 June 2011 - 09:50 PM
i already have a thread for my minis rebuild here http://www.theminifo...howtopic=137592 but i thought id best make a new thread for its next step in its evolution.. a micra transplant.
a week ago i bought this
which has a 1.0 engine
at the moment the plan is to use the 1.0 engine to mock up the frame, once this is done im not sure which way to go. the current thought process is to strap a turbo onto it but theres also a part of me that wants to keep it na but with a 1.3 engine.
either way its going to have a custom intake manifold.
for the intake i will be chopping the flange off the micra inlet and welding it to a Toyota manifold which is a much better design and should gain a bit of power.
Toyota manifold
for simplicity i might ditch all the injection etc and go for megajolt(already on mini) and carb.
currently the engine is ready to be lifted out of the micra.
sadly there wont be much progress until the vtec mini is finished but i'll update when possible
#2 l_jonez
l_jonez
  • 1,453 posts
Posted 09 June 2011 - 08:24 PM
Cough* engines out *cough
#3 minidream94
minidream94
  • 1,233 posts
Posted 09 June 2011 - 08:30 PM
Sounds an interesting project man :thumbsup: Id like to drop a 1300 micra engine into my mayfair and then slap a turbo on it and do some head work and stuff :- keep the pictures coming as ill be watching this closely.
also what sthe manifold off of?
Edited by minidream94, 09 June 2011 - 08:31 PM.
#4 l_jonez
l_jonez
  • 1,453 posts
Posted 09 June 2011 - 08:45 PM
It's from a Toyota 4-age engine
#5 l_jonez
l_jonez
  • 1,453 posts
Posted 12 June 2011 - 07:45 PM
Started playing with the inlet manifold today
Toyota manifolds flange chopped off
Micra flange cut off
Hopefully the end result when welded
Will have to wait untill the engine is the car to see how well it fits but I can cut it shorter if needed.
#6 l_jonez
l_jonez
  • 1,453 posts
Posted 13 June 2011 - 07:11 PM
Have to order some steel to create the subframe so whilst I wait im doing little things to keep me occupied. Today I ported the micra flange a bit.
Lined up the manifold gasket and scribed around it
Then set about enlargeing the port
Hopefully the exhaust manifold will turn up tomorrow which means I can get that chopped and welded
#7 rids
rids
  • 670 posts
Posted 13 June 2011 - 07:13 PM
what you doing for exhaust manifold?
#8 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 13 June 2011 - 07:16 PM
i still dont see how you are going to get fuel equally down all the intake .. ? as there was never fuel running down them
#9 l_jonez
l_jonez
  • 1,453 posts
Posted 13 June 2011 - 07:24 PM
The fuel injectors are right next to the head so if I keep the EFI its ok. If I go carb ill have to look how well it flows on a simulation (solid works) and see what I have to change
Edited by l_jonez, 13 June 2011 - 07:28 PM.
#10 l_jonez
l_jonez
  • 1,453 posts
Posted 13 June 2011 - 07:26 PM
Exhaust manifold will be a modified ( bigcheif style) K series. Managed to get a brand spanking new one off ebay :thumbsup:
#11 James_1
James_1
  • 253 posts
Posted 14 June 2011 - 05:47 PM
Flow won't be the problem - icing is what will potentially kill it with such a long inlet. I'm really interested to see how this goes so please keep us updated, I want carbs and a mechanical dizzy on mine :)
#12 The Marcos Graveyard
  • 11 posts
  • Local Club: Irish Mini Owners Club
Posted 17 June 2011 - 11:29 AM
Remember that the 1ltr gear box and the 1.3 are very different in size, if you mock up with the 1ltr you'll find the 1.3 wont fit. Better to mock up the 1.3 initially.
The gear linkages are different as is the gearbox oil filler hole and the CV joints.
#13 Artstu
Artstu
  • 830 posts
Posted 17 June 2011 - 11:54 AM
Only the very early 1.0L had the smaller box and driveshafts, if the engine and box are from the red Micra the box and driveshafts will be the same size as those from a 1.3L car.
Edited by Artstu, 17 June 2011 - 11:55 AM.
#14 l_jonez
l_jonez
  • 1,453 posts
Posted 17 June 2011 - 02:22 PM
What he said , its the same size box just different ratios
#15 l_jonez
l_jonez
  • 1,453 posts
Posted 19 June 2011 - 05:58 PM
Wiring now stripped down to the just the engine loom. Got to say its a lot smaller than the vtec loom.
    Bing (1)
