Just Bought My First 12g295!
Posted 08 March 2010 - 09:23 PM
It seems to be in really good shape - no evidence of valve recession, and only minimal play of the valves in their guides, though approximately how much play would be acceptable? Obviously I will lap the valves into their seats before refitting them, and will replace all of the stem oil seals/o-rings, but I don't think there's any need to replace any valves or guides... I need to confirm the chamber volumes and do the compression ratio maths, but i've been told they're down to 22.6cc already, and the mating face is perfectly flat so i don't think I'll need to do a skim.
Anything else i should check for or consider replacing?
Thanks, Ben
Posted 09 March 2010 - 12:29 PM
Do the sums accurately so that it's correct.
Posted 09 March 2010 - 02:11 PM
Your 998 will have dished pistons whereas the original 998 onto which the 295 head was fitted had raised-top pistons. So you will need to measure and calculate the compression ratio to be sure that it's within acceptable limits. A good figure to aim for is 10:1 or thereabouts.
Think you could be wrong on the dished pistons. Sisters got an 89 and brothers got a 90, both are flat top pistons.
But you are right about a non modified head needing skimming to get the compression back up, the 12g295 as a bigger volume combustion chamber than the later standard 998.
Posted 09 March 2010 - 03:29 PM
Some 998s have dished pistons, probably the low compression engines.
Posted 09 March 2010 - 03:42 PM
Posted 09 March 2010 - 05:06 PM
The 998 has had raised, flat-top and dished pistons on different models over the past 48 years from Riley Elf onwards, thro' Cooper 998, and all standard production 998's including those fitted to vans, pick-ups, etc.
Posted 09 March 2010 - 06:08 PM
Posted 09 March 2010 - 06:13 PM
its true, thats why i put my old head back on my early 998. the amount that needs taken off the 12g295 for dished pistons will go into the oil gallery. an 89 mini would have flat top pistons im sure. the best thing to do is to check your engine number on the engine guide in the FAQ or for 100% accuracy- take the head off and look.Just a thought but could fitting a 12g295 to a 998 with dished pistons be a bit of a problem, I've read if you skim to much off the head to raise the compression you can cut into the oil ways ??
Posted 09 March 2010 - 06:14 PM
Posted 09 March 2010 - 06:19 PM
Posted 09 March 2010 - 06:31 PM
if you take a spark plug out then using a tourch you should be able to see if you have flat tops or dished
