I've just purchased some braided Goodridge hoses to replace the rear lines on my Mini but I can't figure out the best way to fit the banjo bolt.
I'm assuming that the banjo end goes to the hard line on the subframe, but it can't attach in the same way as the old flexible ones (i.e. through the hole in the subframe).
If I fit it by just passing it through the bigger hole the line won't be long enough to reach the wheel cylinder (see pic below).
Can anyone shed any light on which whay these fit, or better post a pic?
Andy
