Its got fuel
Turns over, choughs occasionally but no pulse
Tried:
Choke out
Choke out, throttle open
No choke, throttle open
Re checked points and firing order
Tried moving the dissi slightly but all that did was either backfire louder or not at all
Tried adjusting the mixture, still no joy
Is there and default settings that I could try for the carb to see if that helps it to start?
As part of the work done I did replace the
Points and condenser and Spark plugs all set as per the Haynes manual
Witch worked fine the last time I changed any of these items
Any input would be a great help
As I going to give it another try tomorrow with a fresh battery
Thanks,
Karl
Edited by 1984mini25, 28 February 2006 - 04:34 PM.
